Programmable Devices
21616 Discussions
NIOS 2 Development: Compile
drecassiano
I create a NIOS 2 processor in platform designer 18.1 and then transferred into a Verilog file and then I do the following below in Quartus prime lite edition18.1.
  • (double click) core(dir)
  • (select) core_inst.v
  • (click) Open
  • Template to instantiate
  • Select All: Copy
  • Open: DE10_LITE_Golden_Top.v
  • Past Core: change u0 to u3
When I do start analysis and elaboration I get the this error
Error (12006): Node instance "u3" instantiates undefined entity "core". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
If anyone could please help me out on this error?
sstrell
Did you add the .qip or .qsys file to your Quartus project (Project menu -> Add/Remove files in project)?  Either way, your PD system file must be named core.qsys.  core.qip will not be created unless you manually generate your PD system, so it's usually easier to just add the .qsys file to your project so the system gets generated every time you compile your project.
drecassiano
Thanks for the reply. I have tried adding the core.qsys with the DE10_LITE_Golden_Top Verilog as can be seen below but still no luck as the following error messages get shown when compilation is finished.  Let me know if anyone knows the solution?
ShengN_Intel
Do you have any further update or concern?
Sheng
drecassiano
sstrell
Can you show your Platform Designer system?  Something is simply not connected correctly.
drecassiano
I am trying to send the core.qsys file through but the file format is not supported through the forum. how is the best way to send the file?
ShengN_Intel
It'll be easier if you upload a zip, qar, tar, 7z or rar file.
drecassiano
I have posted a .rar file with the files. Let me if you know the solution?
drecassiano
ShengN_Intel
Below are the instantiations of core u3 in DE10_LITE_Golden_Top.v :
.altpll_0_c1_c1k ( ),
.altpll_1_areset_conduit_export (ARDUINO_IO[2]),
.altpll_1_locked_conduit_export (ARDUINO_IO[3])
As sstrell mentioned earlier, this is interconnection problem. I don't see ports above altpll_0_c1_c1k, altpll_1_areset_conduit_export and altpll_1_locked_conduit_export being instantiated in core.v as well as core_inst.v. May be you have to check again. There is no error at altpll_0_c1_c1k because it is not being connected yet.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
ShengN_Intel
Do you have any further update or should I consider the case closed?
ShengN_Intel
Since there are no further feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you.
