Programmable Devices
NIOS in Arria 10
MK_ABQ
新分销商 III
1,079 次查看
A general question. Does Quartus tooling, and Arria 10 (10AX115S2F45I1SG) allows to use 2 NIOS fast core processors in single FPGA?
MK
0 项奖励
1 解答
sstrell
名誉分销商 III
1,065 次查看
Nios is a soft processor, so its use is only limited by available device resources.  And for the fast core, you need a license to create a non-time-limited programming file.
在原帖中查看解决方案
4 回复数
sstrell
名誉分销商 III
1,066 次查看
MK_ABQ
新分销商 III
1,052 次查看
Thank you for the clear response.
0 项奖励
EBERLAZARE_I_Intel
1,046 次查看
Sorry I was late on the first response, just want to check if your questions was addressed and if you have further questions?
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
0 项奖励
EBERLAZARE_I_Intel
1,037 次查看
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
0 项奖励
回复
