RAM to DSP
shxb
hi,
  we have data path : RAM output->normal_reg->DSP_input_reg ,
  there is only one "normal_reg" , but it drives 8 DSPs, timing violation path reported for "RAM output->normal_reg".
  without insert clock cycles , what can we do to fix it?
  maybe move the "DSP_input_reg"  outside DSP block helps? i do not know how to constrains it on RTL, or some other suggestions?
  thanks
sstrell
Enable register duplication to break up the fanout of normal_reg.
RichardTanSY_Altera
Hi @shxb
May I know the suggestion from sstrell helps?
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
