we need update ep4c's fpga and lt's flash epcs64, so I learn an603 use factory image and application image, factory's baseaddr is 0x000000, application base is 0x400000, application can work well, but i find fpga restart again after it work well few time, if i don't use factory's image, my application can work fine long time, once i add factory's image and appliction's image together, it restart again after it work few time, why?
連結已複製
HI CPwb0,
When you convert your programming to .pof file, try to TICK both of "Disable EPCS/EPCQ ID check" and "Disable AS mode CONF_DONE error check" option.
Go to File > Convert Programming file > Advanced.. > "Disable EPCS/EPCQ ID check" / "Disable AS mode CONF_DONE error check"
I hope this will help.
