I've been trying to build a dual boot image for a 10M08DAF484C8G but I can't get it to compile or create an image with two images for CONFIG_SEL selection. Is there a way to do it without IP or remote/local IP? Thanx, Rich
链接已复制
Hi Richard,
You will need to write your own state machine to do so if you don't want to use IP. I would recommend to use IP as it is already there. May i know what do you meant by cannot get it compiled?
Are you having problem in quartus design compilation with this IP?
Thank YOu
Hi Richard,
By seeing at the instantiation, it seems like you instantiated the IP but with no connection on it.
For your information, you also refer to the user guide below to see the flow to process to use this IP for remote update:
https://www.intel.com/content/www/us/en/programmable/documentation/sss1430185325021.html#sss1430185602609
Thank You.
Hi Richard,
Apologize that we don't have the solution. Perhaps you can utilize the IP and then write your own state machine to interact with the IP. In your state machine, you will only read the input value (HIGH / LOW) from a certain pin.
Thank You.
