Programmable Devices
21571 Discussions
virtual clock - latch and launch clock on same cycle
NitzanD
I am defining a virtual clock in .fdc file for work with external device as in the link here:
https://www.intel.com/content/www/us/en/docs/programmable/683068/18-1/creating-virtual-clocks.html
When calculating setup timing - Quartus fails on paths from my system_clk to the virtual clock because it refers to it as if the launch and latch are on the same cycle (picture attached).
How can I change Quartus STA to set the launch and the latch clock to be in next cycle ?
Thanks ahead,
Nitzan
sstrell
Very difficult helping with this without seeing your .sdc.  Can you post it?
NitzanD
Do you mean .scf file ?
I synthesize with synplify_premier which uses Quartus for P&R, so I have .fdc file and .scf file
Nurina
Hi Nitzan,
Can you share your .qar file? To generate this, go to Project>Archive Project.
Nurina
NitzanD
where to upload it?
I don't want to share it on the forum.
BR
Nitzan
sstrell
You don't have a .sdc file with your timing constraints in it? (create_clock, set_input_delay, etc.)
Nurina
Hi Nitzan,
You can share in email. I'm sending you an email shortly.
Nurina
NitzanD
Hi, have you seen my email? I sent it as you asked.
Nurina
Yes I have. Can you please try set_multicycle_path as stated in the email? I have sent detailed information in email.
Nurina
NitzanD
In addition to what I sent in email, I want you to see again this picture that happens when I don't define 'multicycle path' :
Also another question - do the real clock and virtual clock should be in the same async group?
set_clock_groups -asynchronous -group [get_clocks { main_clk main_clk_virt}]
BR
Nitzan
SyafieqS
Hi Nitzan,
It seems like you are encountering a setup timing violation issue in your design involving a virtual clock in a .fdc It is hard to see without the full constraint. I am suspecting there might be an issue on the input/output delay calculation that causing the launch and latch clock to be in the same phase.
-From what I am seeing, in the scenario you've described with a real clock and a virtual clock, the concept of asynchronous clock domains might not directly apply. Both clocks are likely derived from the same master clock and are intended to be related, just with different clock frequencies or phases. Therefore, they may not need to be considered as separate asynchronous clock domains
Nurina
Hello Nitzan,
Usually you don't have to specify that real clock and virtual clock are in different clock groups.
As mentioned in email, I think the problem is that you are using the same virtual clock for both input and output delay.
Have you tried using different virtual clocks for input and output delay?
Nurina
NitzanD
I haven't. why should they be different ?
BR
Nitzan
Nurina
Hi Nitzan,
We have not received a reply from you. As such, I now transition this thread to community support. If you have a new question, Feel free to open a new thread or login to ‘ https://supporttickets.intel.com ’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If any answer from the community or Intel Support are helpful, feel free to rank your support experience by rating 4/5 survey. Please let me know of any inconvenience so that I may improve your future service experience.
Have a great day!
Nurina W.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
