Hello ColinS,
I am sorry you are having issues with the Intel® Connectivity Performance Suite, I will be glad to assist you.
In order to investigate further, please download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Steven, SSU log attached as requested
Many thanks for the report.
Please be aware that for now, the Intel® Connectivity Performance Suite version 2.1123.214.2 has been taken down from Download Center due to these issues.
For the moment, please consider the previous version 21.22.1168 as the latest one.
Steven G.
Thanks Steven, I had anticipated that much.
I'm a little confused about the versioning.
The last successful one was: 2.1122.1128.2 and that is still operational.
Regards, Colin.
Many thanks for your response.
You can use version 2.1122.1128.2 if it is still operational.
Let me know if you have any concern.
Steven G.
Yes, thank you, it is still operational, as I mentioned.
Since the thread is solved, we will proceed to close it now.
Steven G.
![](/skins/images/9701FEC4E90D143B667C09F3DB2F340F/responsive_peak/images/icon_anonymous_message.png)
