My new Clevo M570TU Montevina laptop has a Intel WiFi Link 5300 AGN with the latest driver running on Windows 7 x64 (13.0.0.107). I get bluescreens several times a day. If I leave the laptop on when I go to sleep, I often will find that it has automatically restarted because of a BSoD sometime during the night. The stop error is 0x000000d1 and I believe the BSoD says DRIVER_IRQL_NOT_LESS_OR_EQUAL refering to NETw5s64.sys.
It seems the BSoD occurs a lot when utilizing the my WLAN connection a bit more than just surfing. That is running 3-4 torrents, streaming Internet radio and surfing at the same time. I use the newest uTorrent client which again uses the latest Java RE (1.8.5 and 6u17). I am at the moment not using any anti virus software.
In addition to the bluescreens, I often lose my WLAN connection. WLAN is however fine on my other laptops. In these cases I get the event ID 5010 referring to NETw5s64 in my in my Event Log. I resolve this issue by disabling and reenabling the WLAN card, but this is very annoying.
I'm starting to think that the driver is faulty, WLAN on Windows 7 x64 is unstable at the moment, or that maybe my WLAN adapter is faulty.
I ran MemTest on my laptop the whole last night without any errors. I am considering trying another torrent client.
Anybody else having these problems? Any tips is highly appreciated as I'm getting fed up.
Update: I've disabled 11n and power saving on the adapter, but it keeps on giving me bluescreens. A Google search shows that this is a common problem with these Intel adapters. It would really be nice if Intel would acknowledge and address these issues.
I apologize for this inconvenience. Please keep in mind the direct support for Intel® wireless adapters is through the computer manufacturer (O.E.M.) since they integrated the adapters in their systems. They will escalate the case to Intel® if necessary as part of a mutual pre-established agreement.
链接已复制
Hi there,
I just wanted to confirm that I got the same BSOD on a fresh install of Windows 7 64 Bits.
Driver: 13.0.0.107
BSOD error: DRIVER_IRQL_NOT_LESS_OR_EQUAL refering to NETw5s64.sys
Message for Intel: please update your driver or request us more information. I have the dump file and if I can send it to you if you want.
please let us know
Didier
I've been getting the same BSODs and random network drops for months now with the 13.0.0.107 drivers and Windows 7 x64, running 5300 adapters in HP 8530w notebooks. For me it's pretty easily reproducible by transmitting >30-40mbps on a LAN and surfing the web at the same time. It's been happening ever since the first Win7 RC dropped, so it's not as if it's exactly a new problem either.
I had hoped to see better drivers (or other fix) once Windows 7 was released to retail, but it's been about 5 months now since Intel's last driver update and I've just about given up. If this doesn't get fixed soon, I'll definitely be looking for Broadcom wireless adapters from now on (I actually would have already ripped out these POS Intel adapters, but they're whitelisted in the 8530w BIOS.)
I have been in contact with Intel Customer Support, and they refuse to give me support since my card is an OEM product. They told me to contact my reseller which I then did, but my reseller told me they don't have a support deal with Intel. I have since tried another wireless router (3COM vs. D-Link), but the bluescreens still came. My reseller is now offering me a replacement 5300 card, which I don't believe in, but maybe it's worth a try...
I just wish Intel could release a new driver since all the bluescreens people are having are pointing to the driver itself (NETw5s64.sys).
my x200 recently purchased had the same problem. I tried vista drivers etc. Same issue when downloading massive files BSOD - Bad Pool Caller. I reimaged a few times. I recently restored my image and haven't had a problem with the latest Lenovo/Drivers. I tried these a few times before also with BSODs happening. 13.0.0.107 9/15/2009. Vista drivers gave half the throughput but were stable.
A quick update for everyone having this problem:
Microsoft has released a hotfix for BSODs very similar to these, caused be defective power management code. You can read more over at Ars Technica using the following link: http://arstechnica.com/microsoft/news/2010/02/microsoft-details-windows-7-memory-leaks-hangs-freezes.ars http://arstechnica.com/microsoft/news/2010/02/microsoft-details-windows-7-memory-leaks-hangs-freezes.ars
I won't be able to test this until next week, and you should use caution in applying this update as it hasn't been fully tested and might break more things than it fixes, but at least there might be a solution forthcoming (and I might owe one big apology to Intel's driver team.)
I knew I was forgetting something - updating this thread. After some testing, the hotfix doesn't work for me either.
I did notice a new behavior while testing, though - it seems that the BSODs are much more likely immediately after a "recovery" reboot (regardless of hotfix/no hotfix.) I managed to get four of them in quick succession by starting some heavy network traffic immediately after rebooting, but things stay stable for much longer if I do a full shutdown/boot cycle after a BSOD reboot.
I don't know if that has any relevance to anything, but thought I'd mention it.
Intel is aware of this problem and is actively working to resolve the issue. We will update this thread as new information is available.
Thank you,
IleneK
I just wanted you to know that I just replaced my 5300 AGN with another unit from my reseller, but as I tought, it didn't help.
Anyways, thanks for the update IleneK. Makes things a lot easier when you acknowledge the problem. If there's anything I can do to help just let me know.
I thought I'd post this here since it's a top result on google.
I've had Dell send me two new 5300s and a technician to replace my motherboard, but this exact problem continued. I asked them to send me a Broadcom NIC also known as "Dell WLAN 1510" and the problems stopped. The card will do as a replacement until Intel fix their drivers. So people who want to use N should demand their OEM to send them another 802.11n-capable non-Intel card with comparable specification. Dell customers should preferably ask for a card named 1520 since it's closer to Intel's 5300 in terms of performance.
The new drive don't worked for me --> I've got:
Intel(R) WiFi Link 5100 AGN
Driver --> 13.1.1.1 (Date 13.01.2010)
on Windows 7 64bit Home Premium
Here the minidump:
BAD_POOL_CALLER (c2)
The current thread is making a bad pool request. Typically this is at a bad IRQL level or double freeing the same allocation, etc.
Arguments:
Arg1: 0000000000000007, Attempt to free pool which was already freed
Arg2: 0000000000001097, (reserved)
Arg3: 000000000005ca0a, Memory contents of the pool block
Arg4: fffffa8004645a00, Address of the block of pool being deallocated
Debugging Details:
POOL_ADDRESS: fffffa8004645a00
FREED_POOL_TAG: AfdB
BUGCHECK_STR: 0xc2_7_AfdB
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from fffff80002fb760e to fffff80002e85f00
STACK_TEXT:
fffff880`02f1b548 fffff800`02fb760e : 00000000`000000c2 00000000`00000007 00000000`00001097 00000000`0005ca0a : nt!KeBugCheckEx
fffff880`02f1b550 fffff880`01408695 : fffffa80`0515ee8f fffffa80`05698df0 00000000`00000000 fffffa80`0515ee8f : nt!ExFreePool+0xccb
fffff880`02f1b600 fffff880`03e17be7 : fffffa80`0428f420 fffffa80`0515ee18 fffffa80`09b7d470 fffffa80`05692370 : ndis!NdisFreeMemory+0x15
fffff880`02f1b630 fffffa80`0428f420 : fffffa80`0515ee18 fffffa80`09b7d470 fffffa80`05692370 fffff880`02f1b6a0 : NETw5s64+0xdbe7
fffff880`02f1b638 fffffa80`0515ee18 : fffffa80`09b7d470 fffffa80`05692370 fffff880`02f1b6a0 fffff880`03e1c493 : 0xfffffa80`0428f420
fffff880`02f1b640 fffffa80`09b7d470 : fffffa80`05692370 fffff880`02f1b6a0 fffff880`03e1c493 fffffa80`09b7d470 : 0xfffffa80`0515ee18
fffff880`02f1b648 fffffa80`05692370 : fffff880`02f1b6a0 fffff880`03e1c493 fffffa80`09b7d470 fffffa80`04645a00 : 0xfffffa80`09b7d470
fffff880`02f1b650 fffff880`02f1b6a0 : fffff880`03e1c493 fffffa80`09b7d470 fffffa80`04645a00 fffffa80`0628d4b0 : 0xfffffa80`05692370
fffff880`02f1b658 fffff880`03e1c493 : fffffa80`09b7d470 fffffa80`04645a00 fffffa80`0628d4b0 00000000`00000000 : 0xfffff880`02f1b6a0
fffff880`02f1b660 fffffa80`09b7d470 : fffffa80`04645a00 fffffa80`0628d4b0 00000000`00000000 00000000`00000000 : NETw5s64+0x12493
fffff880`02f1b668 fffffa80`04645a00 : fffffa80`0628d4b0 00000000`00000000 00000000`00000000 fffffa80`0515ee8f : 0xfffffa80`09b7d470
fffff880`02f1b670 fffffa80`0628d4b0 : 00000000`00000000 00000000`00000000 fffffa80`0515ee8f fffffa80`056bfda0 : 0xfffffa80`04645a00
fffff880`02f1b678 00000000`00000000 : 00000000`00000000 fffffa80`0515ee8f fffffa80`056bfda0 fffff880`03ffc082 : 0xfffffa80`0628d4b0
STACK_COMMAND: kb
FOLLOWUP_IP:
NETw5s64+dbe7
fffff880`03e17be7 ?? ???
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: NETw5s64+dbe7
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: NETw5s64
IMAGE_NAME: NETw5s64.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4b4df6b9
FAILURE_BUCKET_ID: X64_0xc2_7_AfdB_NETw5s64+dbe7
Followup: MachineOwner
I have nearly the same problem on a brand new lenovo R400 with Intel 5100 AGN and win7 pro 64bit. I think its only happen in high load situations (downloading with almost 2mbyte/second) and additionally high cpu-load over night. The laptop crashed after 8 hour's, so the driver shows this symptoms only after a couple of hours i think´, but i will watch it the next days. Driver version is 13.1.1.1 (13.01.2010).
Thank you for any help or an updated driver
*** WARNING: Unable to verify timestamp for NETw5s64.sys
*** ERROR: Module load completed but symbols could not be loaded for NETw5s64.sys
Probably caused by : NETw5s64.sys ( NETw5s64+dbe7 )
1: kd> !analyze -v
* Bugcheck Analysis *
Arguments:
Arg3: 00000000e5ad00c1, Memory contents of the pool block
Arg4: fffff88006630094, Address of the block of pool being deallocated
Debugging Details:
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from fffff80002bfe60e to fffff80002accf00
STACK_TEXT:
fffff880`02f227b8 fffff800`02bfe60e : 00000000`000000c2 00000000`00000007 00000000`00001097 00000000`e5ad00c1 : nt!KeBugCheckEx
fffff880`02f227c0 fffff880`01648695 : fffffa80`0469a29f fffffa80`0628d8b0 00000000`00000000 fffffa80`0469a29f : nt!ExFreePool+0xccb
fffff880`02f22870 fffff880`05658be7 : fffffa80`04b4dc80 fffffa80`0469a228 fffffa80`07ab4710 fffffa80`05912770 : ndis!NdisFreeMemory+0x15
fffff880`02f228a0 fffffa80`04b4dc80 : fffffa80`0469a228 fffffa80`07ab4710 fffffa80`05912770 fffff880`02f22910 : NETw5s64+0xdbe7
fffff880`02f228a8 fffffa80`0469a228 : fffffa80`07ab4710 fffffa80`05912770 fffff880`02f22910 fffff880`0565d493 : 0xfffffa80`04b4dc80
fffff880`02f228b0 fffffa80`07ab4710 : fffffa80`05912770 fffff880`02f22910 fffff880`0565d493 fffffa80`07ab4710 : 0xfffffa80`0469a228
fffff880`02f228b8 fffffa80`05912770 : fffff880`02f22910 fffff880`0565d493 fffffa80`07ab4710 fffff880`06630094 : 0xfffffa80`07ab4710
fffff880`02f228c0 fffff880`02f22910 : fffff880`0565d493 fffffa80`07ab4710 fffff880`06630094 fffffa80`0442fdc0 : 0xfffffa80`05912770
fffff880`02f228c8 fffff880`0565d493 : fffffa80`07ab4710 fffff880`06630094 fffffa80`0442fdc0 00000000`00000000 : 0xfffff880`02f22910
fffff880`02f228d0 fffffa80`07ab4710 : fffff880`06630094 fffffa80`0442fdc0 00000000`00000000 00000000`00000000 : NETw5s64+0x12493
fffff880`02f228d8 fffff880`06630094 : fffffa80`0442fdc0 00000000`00000000 00000000`00000000 fffffa80`0469a29f : 0xfffffa80`07ab4710
fffff880`02f228e0 fffffa80`0442fdc0 : 00000000`00000000 00000000`00000000 fffffa80`0469a29f fffffa80`059bd080 : 0xfffff880`06630094
fffff880`02f228e8 00000000`00000000 : 00000000`00000000 fffffa80`0469a29f fffffa80`059bd080 fffff880`0583d082 : 0xfffffa80`0442fdc0
STACK_COMMAND: kb
FOLLOWUP_IP:
NETw5s64+dbe7
fffff880`05658be7 ?? ???
FAILURE_BUCKET_ID: X64_0xc2_7_NETw5s64+dbe7
