Wireless
8506 Discussioni
The drivers are updated. I try to pair a Sennheiser HD 4.50 BTNC headset . The bluetooth network connection cannot find the device and it doesn't find it in any way. I'd appreciate your help . The same thing happens to me on Linux
RSalv6
Principiante
14.338Visualizzazioni
Wireless-AC 7265 Intel Dual Band Wireless-AC 7265 Card.Microsoft Windows 10 Pro (64 bits)Version (Build) 1909 (10.0.18363).
Driver DetailsUpdate available
    ProviderIntel
    Version19.51.26.1
    Date10 / 29/2019
    Device Details
    ManufacturerIntel Corporation
    AvailabilityRunning at full power
    StatusThis device is working properly.
    InstalledTrue
    MAC Address28: C6: 3F: FC: 7F: 51
    Service NameNetwtw04
    Device IdPCI \ VEN_8086 & DEV_095A & SUBSYS_50108086 & REV_59 \ 28C63FFFFFFC7F5100
    Revision59 (REV D)
Microsoft Wi-Fi Direct Virtual Adapter
    Driver Details
    ProviderMicrosoft
    Version10.0.18362.1
    Date6 / 21/2006
    Device Details
    ManufacturerMicrosoft
    StatusThis device is disabled.
    InstalledTrue
    Service Namevwifimp
    Device Id {5D624F94-8850-40C3-A3FA-A4FD2080BAF3} \ VWIFIMP_WFD \ 5 & 1400447E & 2 & 18 in Windows 10 Professional with Intel® Wireless Bluetooth®, Driver DetailsUp to date
    ProviderIntel Corporation
    Version20.100.6.4
    Date3 / 10/2019
    Device Details
    StatusOK
    Device IdUSB \ VID_8087 & PID_0A2A
Sennheiser HD 4.50 BTNC headset It has NFC, It has wireless Bluetooth 4.0 with apt-X for a fast connection with compatible devices
Linux (Ubuntu Mate 19.19 Eoan).
8 Risposte
AdrianM_Intel
Dipendente
13.982Visualizzazioni
Hello RSalv6,
Please run the following tool and attach the report generated.
1. Intel® System Support Utility (Intel® SSU)
  • Intel® SSU Download link
  • Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
Questions:
  • Was it working before?
  • Have you tried to change the wireless band form your router settings like 2.4GHz to 5.0GHz? (There could be some interference)
  • Does the issue happen only with this computer or any other device?
  • Have you tested any other Bluetooth device on your computer? if so does it work?
Note:
For Linux* OS we recommend you visit Linux* Support for Intel® Wireless Adapters to get further assistance with Linux* OS.
https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi
Adrian M.
RSalv6
Principiante
The headset never worked, I can't change the band of my router, it only works in 2.4GHz, I disconnected everything around, printer, phone, USB thief, the router is just under the computer (I didn't disconnect it). The headset works well connected to my mobile, my mobile connects well via bluetooth to the computer and with the headphones. thanks for your help. Attached report as requested
AdrianM_Intel
Dipendente
Hello RSalv6,
Were you able to check the previous post?
Let me know if you need more assistance.
Adrian M.
AdrianM_Intel
Dipendente
Hello RSalv6,
Thank you for your reply.
The Bluetooth seems to be working fine with other devices the issue only happens with the headphones, for testing porpuses can you please try the following:
  • Download the latest Bluetooth driver for Intel® Dual Band Wireless-AC 7265.
  • Disconnect the computer from internet access.
  • Open the Control Panel.
  • Click on network adapters.
  • Click Intel® Wireless Bluetooth® Check Delete the driver software for this device, and click Uninstall
  • To complete the uninstall process, restart your system.
  • Run the drivers downloaded in step 1.
Note:
You may need to repeat the above steps several times if your system has an older version of the driver installed.
Adrian M.
RSalv6
Principiante
Hi, thank you for you answer. I had already installed the latest driver as requested in your message, I have even reinstalled the bios. I have reinstalled it again anyway and I get nothing.
My cell phone connects well with my computer and my headphones connect well with my cell phone (it doesn't have NFC technology), my headphones do. I appreciate your help.
AdrianM_Intel
Dipendente
Hello RSalv6,
What is the model of your cell phone?
Is there a chance that you can test a different cell phone, headphones, or any other Bluetooth device to your laptop since the issue might be related to the headphones since other devices are able to get connected to the laptop.
Please let us know if you can connect any other device to your laptop via Bluetooth.
Adrian M.
AdrianM_Intel
Dipendente
Hello RSalv6,
Adrian M.
AdrianM_Intel
Dipendente
Hello RSalv6,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
As a suggestion, it would be good to contact the manufacturer of the headphones for further troubleshooting since it's the only device failing to be connected to the computer it might be necessary to follow some specific steps for pairing.
Adrian M.
Rispondere
