High Speed Transceiver Demo Designs - Intel Agilex® device with F-Tile
cancel
Showing results for
Search instead for
Did you mean:
340 Discussions
High-Speed Transceiver Demo Designs - Intel Agilex® device with F-Tile
IMPORTANT NOTE: For all Prbs (with/without FEC) PCIe development kit designs: Depending on which cable/module you have equipped in your QSFP-DD module, the I2C might hang and stop the software. An easy fix for this is by recompiling the software and disabling the I2C, or you can rework your kit to replace R122 and R127 with 0R resistors.
Index
  1. Multi-Prbs Generators and Checkers
  2. Supporting Documentation for the F-tile Demo Designs on this page
  3. Description of Designs (Excel sheet)
  4. Library of C-functions for F-tile transceivers (FGT/FHT) using AVMM Interface
  5. Scripts with useful procedures for use in the system console with Agilex F-tile
  6. Soft PRBS with RSFEC Demo Designs
  7. Soft PRBS Demo Designs (no FEC)
  8. Superlite II V4 (with/without KRFEC)
  9. Superlite IV (RSFEC)
  10. 400GbE
  11. 100GbE
  12. 25GbE
  13. 10GbE
  •  (28/04/2021) Collection of Multi-Prbs Generators and Verifiers used in various transceiver demo's with different bit widths: 32-bit, 64-bit, 128-bit, and 256-bit. Includes test bench as well.
2. Supporting documentation for the F-tile Demo Designs
3. Description of all F-tile Demo Designs (Excel file)
4. Library of C-functions for F-tile transceivers using AVMM Interfaces
  • Updated (28/01/2022)
5. Script with useful procedures for use in the system console with Agilex F-tile
  • New (12/08/2022)
    • Functions to be used with F-tile PHY-Direct/FEC-Direct designs/F-tile Ethernet Hard IP designs (controlling loopbacks, showing PMA settings, performing EHM, setting Media mode to VSR/Optics etc.). Requires NDME to be enabled. Supports both FGT and FHT.
    • ttk-helper-ftile.tcl (V1.0)
Intel Agilex® device I-Series PCIe development kit
  • NEW (11/12/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 2x4 channel 25.78125 Gbps soft PRBS test design with RSFEC (528,514) in 2x100G Aggregate mode using FGT transceivers connected to QSFPDD0 and QSFPDD1
  • Updated (18/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): 1x8 channel 53Gbps PAM4 soft PRBS test design with KPFEC (544,514) in 400G Aggregate mode using FGT transceivers connected to QSFPDD1
  • NEW (06/12/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 2x4 channel 53Gbps PAM4 soft PRBS test design with KPFEC (544,514) in 200G Aggregate mode using FGT transceivers connected to QSFPDD's
  • Updated (06/12/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 2x4x1 channel PAM4 53.125 Gbps soft PRBS test design with KPFEC (544,514) Fractured mode using FGT transceivers connected to QSFPDD's + dynamically reconfigurable internal noise.
Intel Agilex® device I-Series SI/SOC Board
  • NEW (06/12/2021) Intel Agilex® device I-Series SI/SOC Board (ES Version) (4 F-tile devices): 2x8 channel 53Gbps PAM4 soft PRBS test design with KPFEC (544,514) in 400G Aggregate mode using FGT transceivers connected to QSFPDD0 and QSFPDD1
  • NEW (06/12/2021) Intel Agilex® device I-Series SI/SOC Board (ES Version) (4 F-tile device): 1x8 channel 53Gbps PAM4 soft PRBS test design with KPFEC (544,514) in 400G Aggregate mode using FGT transceivers connected to QSFPDD0
Intel Agilex® device I-Series HS Demo Board
  • NEW (02/02/2022) Intel Agilex® device I-Series SI/SOC Board (ES Version) (4 F-tile devices): 2x8x1 channel 53Gbps PAM4 soft PRBS test design using FGT transceivers connected to QSFPDD0 and QSFPDD1
  • Updated (31/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): 2x4x1 channel PAM4 53.125 Gbps soft PRBS test design using FGT transceivers connected to QSFPDD's with dynamically reconfigurable internal noise logic.
  • (08/10/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 2x4x1 channel NRZ 25.78125 Gbps soft PRBS test design using FGT transceivers connected to QSFPDD's
  • (08/10/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 2x4x1 channel PAM4 53.125 Gbps soft PRBS test design using FGT transceivers connected to QSFPDD's
  • (08/10/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 3x4x1 channel PAM4 53.125 Gbps soft PRBS test design using FGT transceivers connected to QSFPDD's
  • Updated (26/01/2022) Intel Agilex® device I-Series HS Demo Board (ES Version): 4x1 channel PAM4 53.125 Gbps soft PRBS test design using FHT transceivers connected to OSFP800
  • Updated (26/01/2022) Intel Agilex® device I-Series HS Demo Board (ES Version): 4x1 channel PAM4 106 Gbps soft PRBS test design using FHT transceivers connected to OSFP800
8. Superlite II V4 (with/without KR FEC)
  • NEW (18/01/2022) Intel Agilex® device I-Series SI/SOC Board (ES Version) (4 F-tile devices): Superlite IV design using 4 instances (one per F-Tile) of 2 times a PHY direct IP configured in 200Gbps with KPFEC, bonded across 8 lanes at 53.125 Gbps to transport 400 Gbps of raw data (transparent transmission of a 1,024-bit bus), total bandwidth = 4x400Gbps = 1.6 Tbps
  • NEW (18/01/2022) Intel Agilex® device I-Series SI/SOC Board (ES Version) (4 F-tile devices): Superlite IV design using 4 instances (one per F-Tile) of 3 times a PHY direct IP configured in 200Gbps with KPFEC, bonded across 12 lanes at 53.125 Gbps to transport 600 Gbps of raw data (transparent transmission of a 1,536-bit bus), total bandwidth = 4x600Gbps = 2.4 Tbps
  • NEW (26/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): Superlite IV design using 4 instances of 1 PHY direct IP configured in 100Gbps with KPFEC, bonded across 2 lanes at 53.125 Gbps to transport 100 Gbps of raw data (transparent transmission of a 256-bit bus), total bandwidth = 4x100Gbps = 400 Gbps.
  • NEW (18/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): Superlite IV design using 3 times a PHY direct IP configured in 200Gbps with KPFEC, bonded across 12 lanes at 53.125 Gbps to transport 600 Gbps of raw data (transparent transmission of a 1,536-bit bus)
  • Updated (18/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): Superlite IV design using 2 times a PHY direct IP configured in 200Gbps with KPFEC, bonded across 8 lanes at 53.125 Gbps to transport 400 Gbps of raw data (transparent transmission of a 1,024-bit bus)
10. 400GbE
11. 100GbE
12. 25GbE
13. 10GbE
Comments
Thanks for posting this info!
Version history
Last update:
‎03-13-2023 05:32 PM
Updated by:
