Intel® ARC™ Graphics
3294 Discussions
Lost Ark Freezing randomly B580
fpspls
Basically the same issue as other have posted in this forum. such as
https://community.intel.com/t5/Intel-ARC-Graphics/ARC-B580-Get-freezing-when-play-LOST-ARK/td-p/1696204
i am playing on the NA server of Lost Ark. just upgraded from GTX1080 to B580 ASROCK Challenger card
GTX1080 never had any freeze issues
Lost ark will freeze and not full crash, game picture still there, some examples of where it crashes,
- when entering chaos dungeon, it froze instantly
- during Aegir Raid Gate 1 in middle of the fight
I do notice FPS seems low in raid running at 1080P, it feels like it runs worse than my previous GTX1080 which is very disappointing
i also notice the same issue where monsters or players spawn in on the map, there is lag
I have resize bar on and paired with 5600x3d running 6989 driver.
already tried DDU and reinstalling GPU drivers twice
verified lost ark game files
with B580 specs, it should be easy able to maintain 120fps but its very shaky and not stable, jumps around 50-80fps which is on par/worse than GTX1080
JedG_Intel
Hello fpspls,
To assist you effectively, kindly the information below.
1. Was this functioning correctly before?
2. Are there any applications running in the background that might be using significant system resources or causing conflicts?
3. Have you tried adjusting the graphics settings in Lost Ark?
4. Which game distribution platform is being used (Steam, Epic Games, etc.)?
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
fpspls
1. yes it was functioning correctly with my old GPU GTX 1080, problems occurred when i installed B580
2. no, only the game is running.
3. I have tried lowest settings, same issue.
4. Steam
JedG_Intel
Hello fpspls,
Thank you for sharing all this information
To further troubleshoot the issue, please try the outlined steps below.
1. Update the BIOS to the latest version
2. Check for Windows update
3. Reinstall the game.
Should the issue persist, it would be greatly appreciated if you could provide a brief video clip demonstrating the problem.
Best regards
Jed G.
fpspls
1. BIOS is already on the latest version 5031
2. Windows is up to date
3. Tried that today and same issue
another thing i notice in task manager while seeing low FPS like 30FPS in an area that should be higher. I see in task manager the card only use 5GB VRAM, seems like it is stuck at 5GB? is that normal?
wateredIce
JedG_Intel
Hello fpspls,
I appreciate you for trying the recommendations that I shared. VRAM usage can vary depending on the game or application, resolution, texture quality, and other graphical settings.
Since the issue persists, we'll need to investigate this matter further. I'll get back in touch as soon as an update is available.
Best regards
Jed G.
VonM_Intel
Hello fpspls,
Thank you for patiently waiting. We are currently investigating the issue you encountered. To help us look into this further, could you kindly clarify the following details:
  • Where did you download the game? Was it from WeGame as well?
  • Could you share your in-game settings?
  • Have you tried installing the latest graphics driver, version 32.0.101.7026 WHQL Certified, to see if this helps resolve the issue?
  • What troubleshooting steps have you already attempted before contacting us? This will help us avoid suggesting duplicate steps.
 we kindly request that you create your own dedicated thread for this concern so we can provide more focused support specific to your issue.
Best regards
Von M.
fpspls
    • Steam
    • I have tried lowest settings or highest, doesnt matter
    • no i did not try the latest graphics driver, ive already switched to another GPU due to this unresolved issue for many others, it has been happening for months with no resolution
    • I already stated in my original post what i have tried and you also asked duplicate questions that are already answered. it doesnt seem like this is getting anywhere like all the other threads of people posting the same problem
JedG_Intel
Hi fpspls,
I'm checking to see if you were able to review our additional questions. Kindly share this information at your earliest convenience.
Jed G.
JedG_Intel
Hello fpspls,
Thank you for providing the additional information. I truly appreciate the time you took to share your experience. I would also like to extend my sincere apologies for the inconvenience you encountered that led to switching to another GPU.
It would be incredibly helpful if you could try the recently released driver update that may address the issue you were facing.
Best regards
Jed G.
JedG_Intel
Hi fpspls,
I'm checking to see if you were able to review my previous post. Please let me know if you need further assistance so we can proceed accordingly
Jed G.
JedG_Intel
Hello fpspls,
Thank you for your patience while I investigated this matter. Based on our research, it appears that the freezing issue you're experiencing may be related to the game itself rather than your GPU hardware. I found multiple reports from users across different GPU brands experiencing similar freezing problems with this game.
I also found several community discussions that may be helpful in understanding this issue better. These reports show similar freezing problems occurring across various GPU configurations:
Reddit Community Reports:
Steam Community Discussion:
International Community Reports:
With this, I recommend contacting the game developer directly for assistance, as they would be best positioned to address game-specific issues and provide targeted solutions.
I will also close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Best regards
Jed G.
