17249 討論
I can't install devices arria10 (all part). Why?
Длаза
新手
2,752 檢視
I did install quartus prime 18.0SE. Load devices "Arria10". When I launch Device Installer, in the “select components” window, after clicking next, a message appears: you didn't select any component for install. What should I do?
0 積分
8 回應
sstrell
榮譽貢獻者 III
2,640 檢視
Did you download the 3 device installation files (.qdz) needed?
https://fpgasoftware.intel.com/18.0/?edition=standard&platform=windows
#iwork4intel
Длаза
新手
2,640 檢視
yes of course
sstrell
榮譽貢獻者 III
2,640 檢視
So it doesn't work even after pointing the device installer to the location of the .qdz files? Weird. I'd try downloading them again, double-checking to make sure they are the correct version of the files for the version of Quartus you've installed.
#iwork4intel
Длаза
新手
2,640 檢視
I repeated downloading again and got the same result.
sstrell
榮譽貢獻者 III
2,640 檢視
If they’re grayed out like that, it means the device is already installed. Are you saying that when you create a new project or try to select an A10 device for an existing project that Quartus tells you the device is not installed? If so, I’d just uninstall Quartus and start over.
#iwork4intel
RichardTanSY_Altera
2,640 檢視
Hi, it seems to me that the Arria 10 device has been installed. Do you see any further issues after Quartus re-installation?
Длаза
新手
2,640 檢視
Thank you. I reinstalled Quartus and components. It work.
RichardTanSY_Altera
2,640 檢視
I'm glad that the issue has been solved. I will proceed to close this case.
p.s. Don’t forget to Reply, and Select the Best Solution. :)
回覆
