17267 讨论
VHDL Package not detected by Modelsim
ZKhan1
新手
18,366 次查看
Hi all ,
I am using Quartus Prime ver 16.0 for compilation of my vhdl project files , the project compiles fine without any errors , but when i start simulation the Modelsim cantt seem to find my package file .
Modelsim version : ModelSim ALTERA STARTER EDITION 10.4d
Although i made a "work" folder myself and pasted the vhdl package in it , but still no effect , then i copied the folder and pasted it in D:\Quartus_projects\i2c_audio_Fir_filtr1p1\simulation\modelsim
 Still i get this error :
# vcom -93 -work work {D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd}
# Model Technology ModelSim ALTERA vcom 10.4d Compiler 2015.12 Dec 30 2015
# Start time: 15:50:44 on Mar 07,2022
# vcom -reportprogress 300 -93 -work work D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd
# -- Loading package STANDARD
# -- Loading package TEXTIO
# -- Loading package std_logic_1164
# -- Loading package std_logic_arith
# -- Loading package STD_LOGIC_UNSIGNED
# -- Loading package NUMERIC_STD
# ** Error: (vcom-11) Could not find work.audio_codeci2c_pkg.
# ** Error (suppressible): D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd(11): (vcom-1195) Cannot find expanded name "work.audio_codeci2c_pkg".
# ** Error: D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd(11): Unknown expanded name.
# ** Error: D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd(13): VHDL Compiler exiting
# End time: 15:50:44 on Mar 07,2022, Elapsed time: 0:00:00
# Errors: 4, Warnings: 0
# ** Error: C:/altera_lite/16.0/modelsim_ase/win32aloem/vcom failed.
# Error in macro ./Audio_FIR_filter_run_msim_rtl_vhdl.do line 74
# C:/altera_lite/16.0/modelsim_ase/win32aloem/vcom failed.
# while executing
# "vcom -93 -work work {D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd}"
In my Top vhdl file and in my testbench i have declared it like this :
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
-- USE IEEE.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.ALL;
use ieee.math_real.all;
USE std.textio.ALL;
Library work;
use work.audio_codec_i2c_pkg.all;
Any clue why modelsim is not able to open it ???
0 项奖励
1 解答
sstrell
名誉分销商 III
18,329 次查看
Spelling difference?  audio_codec_i2c_pkg vs. audio_codeci2c_pkg
在原帖中查看解决方案
0 项奖励
26 回复数
sstrell
名誉分销商 III
18,330 次查看
0 项奖励
ZKhan1
新手
16,865 次查看
Thanks i got rid of that error , but now i am getting this error :
# -- Loading package audio_codec_i2c_pkg
# -- Compiling entity tb_audio_ctrl_Top
# -- Compiling architecture testing_audio of tb_audio_ctrl_Top
# ** Warning: D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd(54): (vcom-1207) An abstract literal and an identifier must have a separator between them.
# ** Warning: D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd(55): (vcom-1207) An abstract literal and an identifier must have a separator between them.
# ** Warning: D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd(58): (vcom-1207) An abstract literal and an identifier must have a separator between them.
# End time: 14:35:41 on Mar 08,2022, Elapsed time: 0:00:00
# Errors: 0, Warnings: 5
# vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cycloneive_ver -L cycloneive -L rtl_work -L work -L Fir_left_ch -voptargs="+acc" tb_audio_ctrl_Top.vhd
# vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cycloneive_ver -L cycloneive -L rtl_work -L work -L Fir_left_ch -voptargs=""+acc"" tb_audio_ctrl_Top.vhd
# Start time: 14:35:41 on Mar 08,2022
# ** Error: (vsim-19) Failed to access library 'tb_audio_ctrl_Top' at "tb_audio_ctrl_Top".
# No such file or directory. (errno = ENOENT)
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./Audio_FIR_filter_run_msim_rtl_vhdl.do PAUSED at line 76
0 项奖励
sstrell
名誉分销商 III
16,829 次查看
Can you show the code lines from the file that are mentioned as having issues?
0 项奖励
BikshuNaik
初学者
15,633 次查看
I have generated some IPs in Quartus Prime Pro edition software and due to some reason I am trying to simulate the design in Modelsim -INTEL FPGA Starter edition and I am facing errors like this:
** Error: (vsim-3033) ../.../IP_Folder/pll_div_by2/altera_iopll_1931/sim/stratix10_altera_iopll.v(498): Instantiation of 'fourteennm_iopll' failed. The design unit was not found.
** Error (suppressible): (vsim-19) Failed to access library 'fourteennm_ver' at "fourteennm_ver".
# No such file or directory. (errno = ENOENT).
so can someone please help me? what is my mistake and how to solve this.
0 项奖励
ZKhan1
新手
16,807 次查看
See attached test bench and do file as well .
0 项奖励
ZKhan1
新手
16,806 次查看
Testbench :
-- Testbench for the i2c_audio_ctrl_Top.vhd
LIBRARY ieee;
Library work;
USE work.audio_codec_i2c_pkg.All;
ENTITY tb_audio_ctrl_Top IS
END tb_audio_ctrl_Top;
ARCHITECTURE testing_audio OF tb_audio_ctrl_Top IS
COMPONENT i2c_audio_ctrl_Top
port (
CLOCK_50 : in std_logic;
PUSHB : in std_logic_vector ( 3 downto 0 );
LED : out std_logic_vector ( 3 downto 0 );
SW : in std_logic_vector ( 17 downto 0 );
LEDR : out std_logic_vector ( 17 downto 0 );
LEDG : out std_logic_vector ( 7 downto 0 );
GPIO : out std_logic_vector ( 35 downto 0 ); -- 40-pin Connector
I2C_SCLK : out std_logic;
I2C_SDAT : inout std_logic;
--audio codec ports
AUD_ADCDAT : in std_logic;
AUD_ADCLRCK: out std_logic;
AUD_DACLRCK: out std_logic;
AUD_DACDAT : out std_logic;
AUD_XCK : out std_logic;
AUD_BCLK : out std_logic
END COMPONENT;
0 项奖励
sstrell
名誉分销商 III
16,651 次查看
I'm guessing the simulator doesn't like your use of "us" and "ms" right after a value without a space.
0 项奖励
ZKhan1
新手
16,578 次查看
Thanks again for pointing that out , i did get rid of those warnings , but i still get that error :
0 项奖励
ZKhan1
新手
16,577 次查看
With in Modelsim in the above attached pic , i noticed that Modelsim only has "Fir_left_ch" , although in vhdl top file i have two Fir ip included one for left and other for right channel .  Anyway i right clicked on the tb in the work folder and forced compiled it , and it successfully compiled it and then simulated the tb and it worked . testbench_forcesim.jpgtb_compile.jpg
0 项奖励
ZKhan1
新手
16,575 次查看
I still want to get rid of this annoying error which pops up when i start simulating from Quartus i.e "# ** Error: (vsim-19) Failed to access library 'tb_audio_ctrl_Top' at "tb_audio_ctrl_Top".
Why do i have to force compile and simulate the tb
0 项奖励
SyafieqS
员工
16,465 次查看
0 项奖励
SyafieqS
员工
16,431 次查看
Ahmed,
Let me know if there is any update or concern on this
0 项奖励
ZKhan1
新手
16,412 次查看
This is output of verror 19 :
# Start time: 19:01:11 on Mar 16,2022
verror 19
# common Message # 19:
# The specified library could not be accessed at the specified location.
# Verify that the directories in the path exist and have the proper access
# permissions and that the "_info" file (with proper access permissions)
# exists. This message might be preceded or followed by another message
# that gives more information about the problem.
# The vlib command creates a ModelSim library. The vmap command creates
# the map from a logical library name to the physical library (directory).
# Use the vmap command without arguments to find out how all the libraries
# are mapped. In the absence of a mapping, the library is searched for in
# the current working directory.
# One way this problem can occur is if the mapping for the library in your
# modelsim.ini file contains an environment variable that is not set
# in your environment.
0 项奖励
ZKhan1
新手
16,411 次查看
And this is my modelsim.ini file :
; Copyright 1991-2009 Mentor Graphics Corporation
; All Rights Reserved.
; THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION WHICH IS THE PROPERTY OF
; MENTOR GRAPHICS CORPORATION OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
[Library]
others = $MODEL_TECH/../modelsim.ini
; Altera Primitive libraries
; VHDL Section
; Verilog Section
work = rtl_work
Fir_left_ch = Fir_left_ch
[vcom]
; VHDL93 variable selects language version as the default.
; Default is VHDL-2002.
; Value of 0 or 1987 for VHDL-1987.
; Value of 1 or 1993 for VHDL-1993.
; Default or value of 2 or 2002 for VHDL-2002.
; Default or value of 3 or 2008 for VHDL-2008.
VHDL93 = 2002
; Show source line containing error. Default is off.
; Show_source = 1
; Turn off unbound-component warnings. Default is on.
; Show_Warning1 = 0
; Turn off process-without-a-wait-statement warnings. Default is on.
; Show_Warning2 = 0
; Turn off null-range warnings. Default is on.
; Show_Warning3 = 0
; Turn off no-space-in-time-literal warnings. Default is on.
; Show_Warning4 = 0
; Turn off multiple-drivers-on-unresolved-signal warnings. Default is on.
; Show_Warning5 = 0
; Turn off optimization for IEEE std_logic_1164 package. Default is on.
; Optimize_1164 = 0
; Turn on resolving of ambiguous function overloading in favor of the
; "explicit" function declaration (not the one automatically created by
; the compiler for each type declaration). Default is off.
; The .ini file has Explicit enabled so that std_logic_signed/unsigned
; will match the behavior of synthesis tools.
Explicit = 1
; Turn off acceleration of the VITAL packages. Default is to accelerate.
; NoVital = 1
; Turn off VITAL compliance checking. Default is checking on.
; NoVitalCheck = 1
; Ignore VITAL compliance checking errors. Default is to not ignore.
; IgnoreVitalErrors = 1
; Turn off VITAL compliance checking warnings. Default is to show warnings.
; Show_VitalChecksWarnings = 0
; Keep silent about case statement static warnings.
; Default is to give a warning.
; NoCaseStaticError = 1
; Keep silent about warnings caused by aggregates that are not locally static.
; NoOthersStaticError = 1
; Turn off inclusion of debugging info within design units.
; Default is to include debugging info.
; NoDebug = 1
; Turn off "Loading..." messages. Default is messages on.
; Quiet = 1
; Turn on some limited synthesis rule compliance checking. Checks only:
; -- signals used (read) by a process must be in the sensitivity list
; CheckSynthesis = 1
; Activate optimizations on expressions that do not involve signals,
; waits, or function/procedure/task invocations. Default is off.
; ScalarOpts = 1
; Require the user to specify a configuration for all bindings,
; and do not generate a compile time default binding for the
; component. This will result in an elaboration error of
; 'component not bound' if the user fails to do so. Avoids the rare
; issue of a false dependency upon the unused default binding.
; RequireConfigForAllDefaultBinding = 1
; Inhibit range checking on subscripts of arrays. Range checking on
; scalars defined with subtypes is inhibited by default.
; NoIndexCheck = 1
; Inhibit range checks on all (implicit and explicit) assignments to
; scalar objects defined with subtypes.
; NoRangeCheck = 1
[vlog]
; NoDebug = 1
; Turn off "loading..." messages. Default is messages on.
; Quiet = 1
; Turn on Verilog hazard checking (order-dependent accessing of global vars).
; Default is off.
; Hazard = 1
; Turn on converting regular Verilog identifiers to uppercase. Allows case
; insensitivity for module names. Default is no conversion.
; UpCase = 1
; Turn on incremental compilation of modules. Default is off.
; Incremental = 1
; Turns on lint-style checking.
; Show_Lint = 1
[vsim]
; Simulator resolution
; Set to fs, ps, ns, us, ms, or sec with optional prefix of 1, 10, or 100.
Resolution = ps
; User time unit for run commands
; Set to default, fs, ps, ns, us, ms, or sec. The default is to use the
; unit specified for Resolution. For example, if Resolution is 100ps,
; then UserTimeUnit defaults to ps.
; Should generally be set to default.
UserTimeUnit = default
; Default run length
RunLength = 100
; Maximum iterations that can be run without advancing simulation time
IterationLimit = 5000
; Directive to license manager:
; vhdl Immediately reserve a VHDL license
; vlog Immediately reserve a Verilog license
; plus Immediately reserve a VHDL and Verilog license
; nomgc Do not look for Mentor Graphics Licenses
; nomti Do not look for Model Technology Licenses
; noqueue Do not wait in the license queue when a license isn't available
; viewsim Try for viewer license but accept simulator license(s) instead
; of queuing for viewer license
; License = plus
; Stop the simulator after a VHDL/Verilog assertion message
; 0 = Note 1 = Warning 2 = Error 3 = Failure 4 = Fatal
BreakOnAssertion = 3
; Assertion Message Format
; %S - Severity Level
; %R - Report Message
; %T - Time of assertion
; %D - Delta
; %I - Instance or Region pathname (if available)
; %% - print '%' character
; AssertionFormat = "** %S: %R\n Time: %T Iteration: %D%I\n"
; Assertion File - alternate file for storing VHDL/Verilog assertion messages
; AssertFile = assert.log
; Default radix for all windows and commands...
; Set to symbolic, ascii, binary, octal, decimal, hex, unsigned
DefaultRadix = symbolic
; VSIM Startup command
; Startup = do startup.do
; File for saving command transcript
TranscriptFile = transcript
; File for saving command history
; CommandHistory = cmdhist.log
; Specify whether paths in simulator commands should be described
; in VHDL or Verilog format.
; For VHDL, PathSeparator = /
; For Verilog, PathSeparator = .
; Must not be the same character as DatasetSeparator.
PathSeparator = /
; Specify the dataset separator for fully rooted contexts.
; The default is ':'. For example, sim:/top
; Must not be the same character as PathSeparator.
DatasetSeparator = :
; Disable VHDL assertion messages
; IgnoreNote = 1
; IgnoreWarning = 1
; IgnoreError = 1
; IgnoreFailure = 1
; Default force kind. May be freeze, drive, deposit, or default
; or in other terms, fixed, wired, or charged.
; A value of "default" will use the signal kind to determine the
; force kind, drive for resolved signals, freeze for unresolved signals
; DefaultForceKind = freeze
; If zero, open files when elaborated; otherwise, open files on
; first read or write. Default is 0.
; DelayFileOpen = 1
; Control VHDL files opened for write.
; 0 = Buffered, 1 = Unbuffered
UnbufferedOutput = 0
; Control the number of VHDL files open concurrently.
; This number should always be less than the current ulimit
; setting for max file descriptors.
; 0 = unlimited
ConcurrentFileLimit = 40
; Control the number of hierarchical regions displayed as
; part of a signal name shown in the Wave window.
; A value of zero tells VSIM to display the full name.
; The default is 0.
; WaveSignalNameWidth = 0
; Turn off warnings from the std_logic_arith, std_logic_unsigned
; and std_logic_signed packages.
; StdArithNoWarnings = 1
; Turn off warnings from the IEEE numeric_std and numeric_bit packages.
; NumericStdNoWarnings = 1
; Control the format of the (VHDL) FOR generate statement label
; for each iteration. Do not quote it.
; The format string here must contain the conversion codes %s and %d,
; in that order, and no other conversion codes. The %s represents
; the generate_label; the %d represents the generate parameter value
; at a particular generate iteration (this is the position number if
; the generate parameter is of an enumeration type). Embedded whitespace
; is allowed (but discouraged); leading and trailing whitespace is ignored.
; Application of the format must result in a unique scope name over all
; such names in the design so that name lookup can function properly.
; GenerateFormat = %s__%d
; Specify whether checkpoint files should be compressed.
; The default is 1 (compressed).
; CheckpointCompressMode = 0
; List of dynamically loaded objects for Verilog PLI applications
; Veriuser = veriuser.sl
; Specify default options for the restart command. Options can be one
; or more of: -force -nobreakpoint -nolist -nolog -nowave
; DefaultRestartOptions = -force
; HP-UX 10.20 ONLY - Enable memory locking to speed up large designs
; (> 500 megabyte memory footprint). Default is disabled.
; Specify number of megabytes to lock.
; LockedMemory = 1000
; Turn on (1) or off (0) WLF file compression.
; The default is 1 (compress WLF file).
; WLFCompress = 0
; Specify whether to save all design hierarchy (1) in the WLF file
; or only regions containing logged signals (0).
; The default is 0 (save only regions with logged signals).
; WLFSaveAllRegions = 1
; WLF file time limit. Limit WLF file by time, as closely as possible,
; to the specified amount of simulation time. When the limit is exceeded
; the earliest times get truncated from the file.
; If both time and size limits are specified the most restrictive is used.
; UserTimeUnits are used if time units are not specified.
; The default is 0 (no limit). Example: WLFTimeLimit = {100 ms}
; WLFTimeLimit = 0
; WLF file size limit. Limit WLF file size, as closely as possible,
; to the specified number of megabytes. If both time and size limits
; are specified then the most restrictive is used.
; WLFSizeLimit = 1000
; Specify whether or not a WLF file should be deleted when the
; simulation ends. A value of 1 will cause the WLF file to be deleted.
; The default is 0 (do not delete WLF file when simulation ends).
; WLFDeleteOnQuit = 1
; Automatic SDF compilation
; Disables automatic compilation of SDF files in flows that support it.
; Default is on, uncomment to turn off.
; NoAutoSDFCompile = 1
[lmc]
[msg_system]
; Change a message severity or suppress a message.
; The format is: <msg directive> = <msg number>[,<msg number>...]
; Examples:
; note = 3009
; warning = 3033
; error = 3010,3016
; fatal = 3016,3033
; suppress = 3009,3016,3043
; The command verror <msg number> can be used to get the complete
; description of a message.
; Control transcripting of elaboration/runtime messages.
; The default is to have messages appear in the transcript and
; recorded in the wlf file (messages that are recorded in the
; wlf file can be viewed in the MsgViewer). The other settings
; are to send messages only to the transcript or only to the
; wlf file. The valid values are
; both {default}
; tran {transcript only}
; wlf {wlf file only}
; msgmode = both
0 项奖励
SyafieqS
员工
16,352 次查看
Hi Ahmed,
Are you managed to work on this issue? Is the KDB applicable at your end?
Let me know any update.
0 项奖励
ZKhan1
新手
16,309 次查看
HI ,
I havent been able to resolve this issue the "verror 19" refers to "modeslim.ini" file , but this file is generated by Modelsim-altera , and dont see any variable that is uncorrectly set in it ???
What is KDB ?
0 项奖励
ZKhan1
新手
16,234 次查看
This is Modelsim-Atera output after i run "vmap"
vmap
# Reading modelsim.ini
# "work" maps to directory ./rtl_work.
# "Fir_left_ch" maps to directory ./Fir_left_ch.
# Reading C:/altera_lite/16.0/modelsim_ase/win32aloem/../modelsim.ini
# "std" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../std.
# "ieee" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../ieee.
# "verilog" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../verilog.
# "vital2000" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../vital2000.
# "std_developerskit" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../std_developerskit.
# "synopsys" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../synopsys.
# "modelsim_lib" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../modelsim_lib.
# "sv_std" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../sv_std.
# "altera_mf" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/altera_mf.
# "altera" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/altera.
# "altera_lnsim" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/altera_lnsim.
# "lpm" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/220model.
# "220model" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/220model.
# "maxii" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/maxii.
# "maxv" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/maxv.
# "fiftyfivenm" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/fiftyfivenm.
# "sgate" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/sgate.
# "arriaii" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/arriaii.
# "arriaii_hssi" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/arriaii_hssi.
# "arriaii_pcie_hip" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/arriaii_pcie_hip.
# "arriaiigz" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/arriaiigz.
# "arriaiigz_hssi" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/arriaiigz_hssi.
# "arriaiigz_pcie_hip" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/arriaiigz_pcie_hip.
# "stratixiv" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/stratixiv.
# "stratixiv_hssi" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/stratixiv_hssi.
# "stratixiv_pcie_hip" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/stratixiv_pcie_hip.
# "cycloneiv" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/cycloneiv.
# "cycloneiv_hssi" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/cycloneiv_hssi.
# "cycloneiv_pcie_hip" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/cycloneiv_pcie_hip.
# "cycloneive" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/cycloneive.
# "stratixv" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/stratixv.
# "stratixv_hssi" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/stratixv_hssi.
# "stratixv_pcie_hip" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/stratixv_pcie_hip.
# "arriavgz" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/arriavgz.
# "arriavgz_hssi" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/arriavgz_hssi.
# "arriavgz_pcie_hip" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/arriavgz_pcie_hip.
# "arriav" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/arriav.
# "cyclonev" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/cyclonev.
# "twentynm" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/twentynm.
# "twentynm_hssi" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/twentynm_hssi.
# "twentynm_hip" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/twentynm_hip.
# "fourteennm" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/vhdl/fourteennm.
# "altera_mf_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/altera_mf.
# "altera_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/altera.
# "altera_lnsim_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/altera_lnsim.
# "lpm_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/220model.
# "220model_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/220model.
# "maxii_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/maxii.
# "maxv_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/maxv.
# "fiftyfivenm_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/fiftyfivenm.
# "sgate_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/sgate.
# "arriaii_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/arriaii.
# "arriaii_hssi_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/arriaii_hssi.
# "arriaii_pcie_hip_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/arriaii_pcie_hip.
# "arriaiigz_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/arriaiigz.
# "arriaiigz_hssi_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/arriaiigz_hssi.
# "arriaiigz_pcie_hip_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/arriaiigz_pcie_hip.
# "stratixiv_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/stratixiv.
# "stratixiv_hssi_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/stratixiv_hssi.
# "stratixiv_pcie_hip_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/stratixiv_pcie_hip.
# "stratixv_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/stratixv.
# "stratixv_hssi_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/stratixv_hssi.
# "stratixv_pcie_hip_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/stratixv_pcie_hip.
# "arriavgz_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/arriavgz.
# "arriavgz_hssi_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/arriavgz_hssi.
# "arriavgz_pcie_hip_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/arriavgz_pcie_hip.
# "arriav_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/arriav.
# "arriav_hssi_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/arriav_hssi.
# "arriav_pcie_hip_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/arriav_pcie_hip.
# "cyclonev_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/cyclonev.
# "cyclonev_hssi_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/cyclonev_hssi.
# "cyclonev_pcie_hip_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/cyclonev_pcie_hip.
# "cycloneiv_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/cycloneiv.
# "cycloneiv_hssi_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/cycloneiv_hssi.
# "cycloneiv_pcie_hip_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/cycloneiv_pcie_hip.
# "cycloneive_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/cycloneive.
# "twentynm_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/twentynm.
# "twentynm_hssi_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/twentynm_hssi.
# "twentynm_hip_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/twentynm_hip.
# "fourteennm_ver" maps to directory C:/altera_lite/16.0/modelsim_ase/win32aloem/../altera/verilog/fourteennm.
0 项奖励
ZKhan1
新手
16,233 次查看
This is vmap output of a working testbench another project :
# vmap
0 项奖励
SyafieqS
员工
16,039 次查看
Ahmed,
What is KDB ?
The Intel® FPGA Knowledge Base page provides links to applicable articles that span a variety of FPGA related issues. You may refer to link below for more KDB
https://www.intel.com/content/www/us/en/support/programmable/kdb-filter.html#sort=%40articlepublisheddate%20descending
You probably need to reinstall Modelsim and see if it can detect vhdl package for you simulation
0 项奖励
ZKhan1
新手
15,982 次查看
Hi ,
I dont think reinstalling Modelsim can solve the issue , as it is working fine for other projects , the mapping to libraries is perfect .
This modelsim.ini file has be generated again .
Regards ,
Ahmed
0 项奖励
回复
